show snmp
show snmp [get | get-next] object_identifier
Description
Displays the contents of an SNMP MIB object.
Syntax Description
object_identifier Specifies the object identifier for an SNMP MIB object.
Default
N/A.
Usage Guidelines
Use the get option to establish an index into the SNMP MIB. After the get option is executed, you can use the get next option to step through the MIB objects.
The following gets the contents of SNMP object 1.3.6.1.2.1.1.5.0:
show snmp get 1.3.6.1.2.1.1.5.0
system.5.0 = BD-12804
This command was first available in ExtremeXOS 12.4.
Platform Availability
